V
videouser
I orig thought of getting the Panny E85 but ruled that one out because of the RAM and only R-, as i frequently use a 2nd DVD player for watching daily stuff Rw- is probably a must!.
I am thinking of going the Pioneer 520 route as it supports RW-/-R which would be more useful. I know the Tosh X32 is probably a better machine, but I have been put off by the various posts regarding - tech failures with this machine!.(is this so!)
If I go the Pioneer 520 route can I edit RW- on my PC? Will this need to be re-encoded ? and are there any compatibility probs playing RW- in other players / PCs (as long as the disks are finalised and not Cheap!).
Please let me know if I am missing anything from Tosh X32, would the Ram have any advantages? (although the main one is compatibility!!!)
Thanks,
Thanks,
