Pioneer 5100H Disc Back-up function
Discussion in 'Blu-ray & DVD Players & Recorders' started by pio5100h, Nov 30, 2003.
  1. pio5100h
    Nov 30, 2003
    I am new to DVD recording.
    In the user guide for the Pioneer 5100H I read about the "Disc Back-up" function.
    It states it can (a.o.?) perform a full (backup) copy, using the HDD as temporary storage, to either a DVD-R or DVD-RW.
    The process seems very easy indeed.
    I have also enabled 'Optimized recording' - kinda like 'fit to space'.
    Now I have 2 questions, before I try and mess up some discs:
    - Will I be able to copy a >4.7 GB disc this way ? (using optimized rec).
    - Will I be able to backup/copy my non-region coded, non-protected 'factory made' DVD-Video discs this way ?
    (it concerns factory made product demo discs - I know if it is CSS scrambled it won't work).
    If it does work, will it copy all contents, menu's included ?
    Also the Sony BIT enhanced-DVD's (non protected?) - would it for those too ? :confused:
