Pioneer 50MXe1 connection queery
Discussion in 'Plasma TVs' started by raydundas@bluey, Nov 5, 2004.
  1. raydundas@bluey
    raydundas@bluey
    I was going to order a JS technology Scart RGB to Plasma VGA box, to take my Digibox signal to the pioneer 50MXE1 screen, which arrives next week. I am getting the 04 video board, so I can take my DVD players component inputs directly into that.
    I have just downloaded more detailed specs for the screen and it says
    "PC input 1 Mini D-sub 15 Pin , RGB signal (G on Sync compatible)"
    Does this mean I can get a direct cable from my Sky scart RGB to Mini D-Sub and therefor not require the JS technology converter.
    I thought I had everything sussed. Until I read that wee bit, I was sure I needed the converter.
    Ray
  2. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    Unfortunately not. RGB scart is RGBs (composite sync), the plasma requires RGsB (sync on green) or RGBHV (h and v syncs). The JS boxes converter RGBs into RGBHV for plasma displays.
  3. raydundas@bluey
    raydundas@bluey
    Thanks for that. Means I was right and the guy who was worrying me at one of the suppliers was wrong. Your help greatly appreciated.
