Pioneer 506XDE - PC Resolution
Discussion in 'Plasma TVs Forum' started by nanookles, Mar 13, 2006.
  1. nanookles
    nanookles
    Hi there,
    Just a quick question. What resolution should I run a PC through my Pioneer at. I use it solely for watching video files (it is essentially an HTCP).
    So the majority of the content is 16:9.
    Any help very much appreciated.
  2. hddvdman
    hddvdman
    Feb 11, 2003
    6,206
    somethere over there but not near here, there
    +156
    my 505xde is 1280 x 768 - any higher and pic wont be displayed
  3. thowal
    thowal
    If you use HDMI to connect it to the plasma you can get resolution upto 1920x1080, but 720p is often better since your screen doesn't need to scale the picture as much.
    Pioneer uses overscan on all its inputs, except the vga, so you have to set your resolution to 1216x684 with powerstrip or if you have nvidia drivers you can compensate with those.
