Pioneer 506XDE optical out issue? Help Please
Discussion in 'Plasma TVs Forum' started by actionorton, Jan 21, 2008.
  1. actionorton
    actionorton
    Can anyone please help.
    I have a Pioneer 506XDE Plasma with the PDP-RO6XE Media box
    the issue i have is for the first time i have connected both my sky HD and Xbox 360 to my media box using HDMI.
    I then tried to connect my media box to my amp using the digital optical out connection on the back of the media box but there was no sound.
    After hours of messing around and trying a friends amp, i contacted Pioneer who told me that i coudnt use my hdmi as well as optical out as it would not switch.
    Is this correct? I cant believe i spent the best part of £3000.00 18 months ago and not be able to connect hdmi to my screen and not have digital audio?
    Please someone tell me thats wrong and my media box is faulty. :lease::lease:
    Thank you in advance
  2. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,976
    Hi mate :)
    I'm afraid they are correct.........sorry. :(
  3. actionorton
    actionorton
    Thanks for the info :(
    The wife is going to be pleased with me then...Especially when i go out and buy a HDMI amp :)
  4. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,976
    Don't tell her until it's delivered ;) that's my usual routine. :D
  5. toph61
    toph61
    Nov 16, 2005
    23
    3
    Carmarthen
    No. This can be done, or at least it can for the hdmi on input 3. You tell the media box that input 3 is enabled for hdmi AND you then specify that the audio it receives is analogue. The box will then output PCM via your optical cable. I have no idea why it does this (hdmi doesn't carry analog so why the mediabox specifies the option is beyond me!) but it does. Buy here that new dress now!
