Pioneer 505XDE
P
philcool1
Hello All
Help I have a Pioneer 505XDE plasma, (excelent screen) i do not know if this will accept a HDCP handshake i have just bought a DENON 1920 and cannot get the player to recognise the hdmi lead, the red HDMI light just keeps flashing. I have looked at the manual with it and it mentions if the display equipment is not HDCP compliant then no HDMI signal wil be sent.
Anyway hope some one out there can help, as i am HDMIless at the moment and really want to see if there is a difference in quality.
Many Thanks
Phil
Have you switched the HDMI input on, it is off by default on the media box.
Goto the AV it is plugging into, then options and HDMI, it will be off by default?
Bang on it was turned off, many thanks for your reply.
It works a treat now
Phil
The BIG PROBLEM With Your Home AV System EXPLAINED
Back
