Pioneer 505XDE media box to display connection
Discussion in 'Plasma TVs' started by HouseofMu, May 26, 2005.
  1. HouseofMu
    HouseofMu
    Jul 18, 2000
    376
    UK
    +13
    Does anybody know what type of cable is used to connect the media box to the display ?
    I've been told by a dealer its a Pioneer only serial cable, and if I want any longer length than the 3m that it comes with, it'll cost around £250 for a 5m cable !
    I've found a pic of the media box connections, here Is it the socket on the bottom right of that diagram - named 'system' ?
    If it is, it looks like a regular DVI socket too me, but i'd appreciate it if any owners could confirm what the cable actually is.
    thanks
  2. Costas
    Costas
    Jan 14, 2003
    1,662
    63
    Swindon, UK
    +121
    HouseofMu,
    Pioneer provides a 10m cable version (ref PDAH03) that costs around 180 pounds. You should be able to find for a little cheaper if you check around.
    Unfortunately it is the dual cable and function that causes the difference and perhaps problem. The one part of the cable that goes into the media box is a standard DVI to DVI cable that you can buy in various qualities and lengths. The other part of the cable carries the remote control signal information. It can also be bought separately but I think buying the two separate ones instead of the Pioneer offered double you will spend more.
  3. HouseofMu
    HouseofMu
    Jul 18, 2000
    376
    UK
    +13
    yes, done a bit more r&d myself and just discovered it a two function cable.
    I've now found AV Sales do a 5m twin cable pack for £170, using "better quality than Pioneers own" ...
    Thanks for the info and prompt reply.
  4. b5oxo
    b5oxo
    Hi HouseofMu
    Could you let me know the place you have see the cable at £170 as I could do with one for my Pioneer 506XDE I just bought from Comet on line - £3,182.09.
  5. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
  6. HouseofMu
    HouseofMu
    Jul 18, 2000
    376
    UK
    +13
  7. b5oxo
    b5oxo
  8. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    How long do you need? I've still got a couple of 'used once' examples here, a 7m and a 10m. The guy couldn't make up his mind where to put the plasma, moved it 3 times, finished up with the 3m...
  9. londismintlaw
    londismintlaw
    Jan 26, 2006
    69
    Does any body have a spare 3m cable they would like to part with for cash?
    Sid
  10. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    :D Naturally.
  11. b5oxo
    b5oxo
    Hi Maw,
    a 7 mtr one would do me fine, if you could let me know what price and how to contact you.
    Many Thanks
    Tony (b5oxo)
    <How long do you need? I've still got a couple of 'used once' examples here, a 7m and a 10m. The guy couldn't make up his mind where to put the plasma, moved it 3 times, finished up with the 3m...>
