Pioneer 505 XDE
Discussion in 'Plasma TVs' started by Scarface12, Dec 21, 2004.
  1. Scarface12
    Scarface12
    Hi finally got it put up and set up with my existing equipment however when i connect my camcorder to the media box no sound comes from my amp (bose lifestyle 30), any tips?
    :lease:
  2. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    How are you connecting your camcorder?
    What connections do you have from the media box to the amp?
  3. Tantalus
    Tantalus
    Aug 21, 2003
    289
    Aberdeen
    +3
    I would assume you have just connected the SVideo cable but no audio?
  4. Scarface12
    Scarface12
    I am connecting it to s video and using the red and white leads also from the camcorder to the media box
  5. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    Surely you'd need to connect the 'red and white' cables to your amp to get sound from it?!?
  6. astirling
    astirling
    Oct 1, 2004
    800
    28
    Dunfermline
    +44
    Well if the media receiver is connected to the amp then it should carry the signal I would have thought. I have my SKY connected to the media box through scart and my PS2. My media box is connected to my amp via an optical cable and the sound comes through ok for them.
