Pioneer 505 Mounting Kits?
Discussion in 'Home Cinema Buying & Building' started by rrc, Nov 9, 2004.
  1. rrc
    rrc
    Apr 11, 2004
    Sweden
    Hi All,
    I’m moving into a newly built house (here in Sweden) next month and have my new Pioneer PDP 505-HDE purchase stored at the shop, awaiting delivery.
    I would like to mount it flush on the wall and have noticed there are two types of brackets for this.
    PDK-WM02 and
    PDK-WM01
    Does anyone know if these will both fit my screen? If so, what is the best one to buy? I am looking to install the plasma display on drywall with studs behind it (I understand that it’s the studs I need to mount to) if that helps.
    Also, is the remote sensor on the media box or on the display? I would rather the media box was out of site.
    Any help/advice would be greatly appreciated. :thumbsup:
    -rrc
  2. rrc
    rrc
    Apr 11, 2004
    Sweden
    C'mon guys! Haven't any of you 435 or 505 owners wall mounting your panels?
    I know it ain't the most interesting subject on this forum, :boring: but a would really appreciate your input (I need to place an order for a bracket really soon).
    :lease:
    /rrc
