pioneer 505 - modify for dts ??
Discussion in 'Blu-ray & DVD Players & Recorders' started by Suki, Jan 11, 2002.
  1. Suki
    Suki
    Hi all,
    I bought a multiregion 505 a few yrs ago - very good but no dts out ( to the best of my knowledge)
    Anyone know of 3rd parties who will modify to give dts output to my amp ( I dont need a built in dts decoder as I have one in my amp) or am I better off just getting a new player.
    If the latter - will I notice a big improvement in general performance and can anyone suggest a player with dts out, selectable region code and pseudo pal output as a replacement
    Suki
  2. mjn
    mjn
    May 24, 2001
    22,723
    Herts, England
    +10,865
    not possible i'm afraid, and if it were, more than likely going to be same or near the cost of new machine!
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,524
    Somewhere in South Yorkshire
    +5,996
    Unless you are looking for an "excuse" to upgrade your player, I'm not sure I'd bother. The 505 was an excellent and robust machine and, IMHO, the differences between DD5.1 and DTS are more as a result of different sound mixes (louder, more bass) than as a consequence of intrinsic quality. There are often differences in compression ratios, bit rates, etc., but for all practical purposes, these make little audible difference.
    (Sits back and waits for barrage of disagreement).
