Pioneer 505 Component Input Problem
Discussion in 'Plasma TVs Forum' started by killie, Aug 8, 2005.
  1. killie
    killie
    I'm trying to set up My DVD Player through the 505 XDE through Component Cable.
    Have no Problem through Scart. but Through the Cable I lose the Red signal
    My DVD is a Pioneer 575a This will be the second Cable I have tried thought the first one might have been faulty.
    Any suggestions would be most appreciated
  2. MPK
    MPK
    Nov 26, 2004
    478
    London
    +8
    Just to make sure: Have you changed the Input menu of the Pio as well as the DVD menu to component?
  3. killie
    killie
    Thanks for the reply
    Changed them both. I'm trying to borrow an another DVD to see if this makes a difference but I suspect the Plasma perhaps the Media Box ?
  4. MPK
    MPK
    Nov 26, 2004
    478
    London
    +8
    I would think probably the media box. Very strange. My first thought would also have been the cable, but you can easily switch the 3 individual component cables to find that out. It could of course also be the DVD player, so I would definitely try another player before sending in your media box.
