Pioneer 504 HDMI Help
Discussion in 'Plasma TVs Forum' started by Henry, Nov 4, 2004.
  1. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    Help! Just connected up an Arcam DV79 to the media box of my Pioneer 50HDE with an HDMI cable and....Nothing!
    According to the back of the media box this should be input 3. But you press input 3 on the remote and.....nothing.
    I've connected the Arcam to the media box with a Scart lead and that works fine. I've then set the output priority to HDMI in the setup menu on the Arcam DV79 but still nothing.
    I've but am in desperate need of help.
  2. Mr Merrick
    Mr Merrick
    Mar 29, 2002
    462
    London
    +13
    Try contacting your dealer and get the latest firmware/ software update for the DV79. I had a few customers with this problem, but it's quickly rectified. The fix improves the compatibility between the player and HD compliant displays.
  3. Mr Merrick
    Mr Merrick
    Mar 29, 2002
    462
    London
    +13
    Another thought... Switch to input 3. Press home menu on the plasma remote, then if memory serves you should go to 'Option' and possibly 'Input assign' and there should be a heading under 'HDMI'. Set it to 'enable' and this should solve the problem...
  4. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    Cheers for the last one. Problem sorted!
