Pioneer 504/434HDE input questions
Discussion in 'Plasma TVs' started by jfraser, Nov 7, 2003.
  1. jfraser
    jfraser
    I'm going to purchase a 504hde but I have a couple of questions I was hoping someone could answer.
    I downloaded the instruction manual for the plasma, and couldn't find any info about a digital HDMI input....I'm pretty certain that it has one.....was it added after the manual was printed????
    which input is the HDMI port associated with (I thought it was a bit silly to associate both the component and svideo with input3...and having nothing but scart for input 1&2)
    Why does the manual state that a decoder (cable box, sat box) should be connected to input 1
    from the instruction manual....
    Selecting a decoder input terminal
    If you have connected a decoder, select a decoder input
    terminal (INPUT1). (page 33)
    Thanks for your help
  2. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    Yes it's got one HDMI port on input 3... Yes you're right 'it was a bit silly' (understatement - stop it..!)...
    Connect a cable box to input 1 for two reasons, one it is RGB and two the the media box switches on to input 1 by default when you first turn on the system (by pressing 1-9 - RF by pressing 0)...
  3. jfraser
    jfraser
    Simon
    Thanks for the info
  4. Costas
    Costas
    Jan 14, 2003
    1,662
    63
    Swindon, UK
    +121
    jfraser
    I had the same query originally. There is a two page addendum to cover HDMI. You will find the link somewhere in the other 434/534 threads. When I open trhe media box for my 434 last week it was already included there....
