Pioneer 502
Discussion in 'Blu-ray & DVD Players & Recorders' started by utailor, Jan 12, 2005.
  1. utailor
    utailor
    I have the above player and on the spec it says 3D Y/C Separate so i am thinking of getting a RGB to component converter as my lcd tv has component inputs. The reason for this being the signal currently coming from my dvd player is a bit pixlated and blotchy at times and having spoken to a chap a a AV shop they haev said that this unit should correct this problem. Now my questions is has anyone got any opinons on this. How can I use the progressive scan on this dvd player do I need to enable.
    Thanks In advance
