Pioneer 470 - firmware and features
Discussion in 'Blu-ray & DVD Players & Recorders' started by rich_jtg, Dec 13, 2004.
  1. rich_jtg
    rich_jtg
    Mar 13, 2004
    241
    +13
    I recently purchased one of these players to mainly play back Div-X files.
    However, after viewing a couple files, it would appear that the Div-X playback is pretty ropey... the image appears to be very jerky.
    After reading a few threads on here that reported that the playback would be smoother after a firmware upgrade, I tried to use the firmware file from AV Land, but with no success - probably because it is meant for the 575 :rolleyes:
    So I phoned Pioneer today to ask if I could have a firmware disc sent to me.
    During the conversation, I was told that the firmware would only add the subtitle feature to Div-X, and would remove any multi-region feature from the player - something I didn't think was true. :confused:
    If I am just going to use the player for Div-X, am I probably better off just returning the player and purchasing a different one, or is there any way of improving it's performance with MPEG4 files?
    I'm fairly pleased with the player otherwise... the only other gripe being the fact you can't set the output of the scart to RGB at the same time as having component selected, but that's jsut a small thing!
  2. rickardl
    rickardl
    Sep 9, 2004
    744
    46
    Stockholm
    +127
    If it is an Xvid-encoded file, I bet it is the "packed bitstream" problem
    which every player with MediaTek 1389EE suffers from.
    Check with the latest GSpot release if it has both B-VOP and N-VOP.
    Use Mpeg4modifier to unpack the file, takes a minute or so.
    Or if you are playing NTSC files and you have it set to AUTO,
    try setting the player to convert it to PAL, it works pretty well.
  3. rich_jtg
    rich_jtg
    Mar 13, 2004
    241
    +13
    Thanks for your reply - much appreciated!
    It would appear that I was suffering from "packed bitstream problem".
    Had a go with Mpeg4 Modifier 1.2.0, but received an error message every time I opened a file.
    After a bit of Googling I found that it was a common problem, and after a bit more searching found an older version (1.1.0) of Mpeg4 Modifier which appears to unpack files nicely!
    I don't think I'll bother with the firmware update, as I only need to view subtitles occasionally, and would prefer the multiregion feature ot stay intact.
    Thanks again for pointing me in the right direction! :thumbsup:
  4. rockyglw
    rockyglw
    Dec 15, 2002
    99
    +4
    I upgraded my 575 firmware and the multi region function is not affected. I would assume that the 470 would be the same
  5. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,057
    Bristol
    +8,402
    I had jerky playback on my Pioneer DV470 also and it turned out it was because 99% of my files had packet bitstream. I just used the program mentioned above to remove it and they now playback perfectly.
    I do have a few files that I cant load into the program though, it comes up saying "No dummy N-VOP for packet frame".
    Anyone know what this means?
  6. rich_jtg
    rich_jtg
    Mar 13, 2004
    241
    +13
    Indeed... that's what I thought, but according to Pioneer that's not the case... as it's only to get subtitles I don't think it's worth the risk for now.
  7. rich_jtg
    rich_jtg
    Mar 13, 2004
    241
    +13
    That's the error I was receiving when using version 1.2.0
    I downloaded version 1.1.0 and the files worked fine. Maybe worth a try if you are using the new version.
  8. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    You can upgrade the 470 with the 575 firmware but its kinda pointless imo. I have the 470 upgrade disc from Pioneer, if you PM me I can copy it for you.
    The new firmware adds ogg support, divx subtitle and prob some other fixes Pioneer won't tell us about.
    As I've posted so many times now, jerky playback is a packed bitstream problem as everyone else said.
    Updating the 470 with new firmware does NOT effect its region settings. E.g if your machine is region free it stays region free. If your machine is region locked, it stays region locked. Pioneer might not admit to this as they do not support or sell region free machines, they are unlocked by 3rd parties.
  9. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,057
    Bristol
    +8,402
    Thanks for that, tried the older version of the problem and it loaded the files I couldnt load before and they work fine now.
    Out of interest, does anyone who has the newer firmware have Star Wars Episode 2 as it takes forever to load on my DV470 and I was wondering if the newer firmware fixed the problem.
  10. jtf
    jtf
    Nov 19, 2004
    220
    colchester
    +7
    star wars takes about 30 secs to load on my 575 with the updated firmware
  11. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    If anyone wants me the 470 updated firmware original Pioneer cd copied let me know and I'll email it to you. Its only a few mb.
  12. rich_jtg
    rich_jtg
    Mar 13, 2004
    241
    +13
    Check your PMs! :cool:
  13. nogimmix
    nogimmix
    Dec 4, 2003
    2,120
    Kent & Canary Wharf
    +82
    I've just brought a 470 and had a few jerky divx films, just trying out the software to see if I have any joy.
    As for the latest firmware, could someone send it over to me please. ;)
  14. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    private msg me your email addess, you need to be able to accept 1.2mb files.
  15. nogimmix
    nogimmix
    Dec 4, 2003
    2,120
    Kent & Canary Wharf
    +82
    Don't worry mate, I managed to download a updated version last night.
    Cheers anyway.
  16. SUb97
    SUb97
    Nov 21, 2005
    62
    Does anyone know if they ever released a firmware version for the 470 that sorted out the packed bitstream problem?
    It would be great to not have to run most of my avi files through mpeg4 modifier all the time :)
    Steve
  17. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    No they didnt not.
  18. Woziak
    Woziak
    Jan 26, 2006
    87
    +7
    Firmware can't solve it, it's the chipset that's not powerfull enough...
  19. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    The chipset in the 470 could do it as the mediatek chip used is in other players that can do xvid packed bitstream. Its firmware thing, they won't update date it as its a 3 generations old now.
  20. Hkan
    Hkan
