Pioneer 444 sound problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by malcom, May 10, 2002.
  1. malcom
    malcom
    Aug 25, 2001
    526
    +4
    I have a new Pioneer 444 DVD player. Although I normally use "S" video connections today I tried playing a disc with a scart connection going from the Pioneer 444 to a scart of my Toshiba TV and finished up with only getting sound from one speaker.
    I have tried an alternative scart cable with no luck! I have searched through the Pioneer menu settings to see if there was a problem there. can't find one!
    Should the pioneer play stereo via scart connections?
    I have no problem when using "S" video and the phono plugs to the TV. Could there be a problem with the Pioneer unit!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Are you using a fullywired scart or not?
    My Tv is only mono so I use my amp to provide the sound, but my 444 is fine, The scart has a habit of working loose though try taking it out and re connecting.;)
  3. malcom
    malcom
    Aug 25, 2001
    526
    +4
    Hi hornydragon
    Yes. The scart cable seems ok as I have tried it on my DVD recorder and it works fine. The set up consists of 4 speakers plus the TV speaker. Normally I would here sound from right,centre and left but only the left speaker is working when the scart is connected from the Pioneer to one of the TV scarts. I have tried all three scarts on the TV and the result is the same. Malcom
  4. andypandy
    andypandy
    Feb 6, 2002
    594
    Surrey, UK
    +10
    I too would have said that the scart may not be all the way in, but you have stated that you tried another scart , so maybe not.
    Quite simply try it on another tv - the 444 is so slim and portable just take it to a friends/family house and see.
    There now you have the answer
