Pioneer 444 - progressive???
Discussion in 'Blu-ray & DVD Players & Recorders' started by bertha, Feb 26, 2002.
  1. bertha
    bertha
    Oct 25, 2001
    1,351
    +113
    Hello there just doing a bit of casual surfing and turned this one up -
    http://www.dvdcity.com/dvdplayer/dv444.html
    The review of this player on the DVDCITY website described it as having progressive scan output is this a slightly different feature to the UK model or is this ********?
    cheers
    Berth
  2. bertha
    bertha
    Oct 25, 2001
    1,351
    +113
    sorry I forgot you can't say ******** - I mean bollux...:D
  3. encaser
    encaser
    Mar 15, 2001
    2,388
    116
    Suffolk/Essex
    +539
    As it's the US model then you may well expect it, as many US pieces have this for their NTSC material. Unlike UK models unless they are higher end, and in any case the UK ones don't have progressive for PAL which would be great. Harrumph.
    ...mean bollux, hey? So are they a bit testie??!!:p
  4. Justin@UH
    [email protected]
    Feb 21, 2002
    2,192
    63
    Location location location
    +93
    No, you`re looking at the american spec of this model. See www.pioneer.co.uk. US models have component as standard as they don`t have euroconnectors (Scart) to offer RGB out.
    Hope that helps
