Pioneer 43MXE1 and Sync on Composite
Discussion in 'Plasma TVs' started by The Nightfly, Nov 30, 2004.
  1. The Nightfly
    The Nightfly
    Aug 31, 2002
    801
    The New Frontier
    +23
    I'm tempted to buy the PDP-43MXE1. Will the Scart output from a Sky digibox work directly into the RGB+Sync input on the BNC video card without any conversion ? From what I've read so far it looks like it should but I havn't come across any threads where this is being recommended.
    If it does work, how would picture quality compare to the same signal being fed into the VGA port via a J.Sims Scart->VGA converter ?
    And finally, would a RGB->Component converted signal look better than both the above options on this particular panel ?
    thanks,
    Allan
  2. Dutch
    Dutch
    Dec 5, 2002
    2,598
    3
    North Yorkshire
    +282
    Hi Allan,
    Digiboxes output an RGB with combined sync on composite signal. You need to have that sync signal split into H and V, which is what Jon Sim's converter does very well. I believe Jon says that the RGB-VGA converter gives a slightly sharper image than the RGB-YUV converter. Hope this helps.
    Steve
  3. The Nightfly
    The Nightfly
    Aug 31, 2002
    801
    The New Frontier
    +23
    Hi Dutch,
    I'm sure I've read somewhere that the five RGB input sockets on the PDA-5003 board can be configured in the following ways:
    RGsB - 3 sockets used
    RGBS - 4 sockets used
    RGBHV - 5 sockets used
    The second option looks like it should work direct from a digibox using a cable with Scart on one end and seperate R, G, B and Composite plugs on the other. Is this information incorrect ?
    If it is correct I'd be interested to know how picture quality compares to using a Scart to VGA convertor and going in via the VGA socket
    Allan
  4. TheCrow
    TheCrow
    Jul 16, 2004
    613
    28
    London
    +49
    I made the same mistake trying to connect my Sky box to my 50MXE1.
    RGBS is not the same as RGBs.
    The 5003 expects RGBS that is a 5V TTL level sync - S
    The Sky box gives out RGBs, that is composite sync ~0.7V -s
    Therefore the MXE1 will not lock to the sync from the Sky box.
    I think the best solution is a box the strips the syncs from the composite output and converts then to TTL. Leaving the RGB signal untouched.
    This leaves the picture signal in the digiboxes native higher bandwidth RGB
    instead of adding an extra convertion to a lower bandwidth component YUV.
    Keene
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,013
    +2,809
    RGBS is not the same as RGBcvS(RGBwith sync on composite). I don't think it's going to work the way you want. Perhaps someone with an MX01 can check for you.
    Gordon
  6. TheCrow
    TheCrow
    Jul 16, 2004
    613
    28
    London
    +49
    There is a good FAQ about RGB, YUV and Syncs here
  7. Gordon @ Convergent AV
    Jul 13, 2000
    14,013
    +2,809
    Mr Crow beat me to it....
    Of course the signal that the Skybox picks up is digital component.....it's turned from component to RGB in the box......YPrPb to RGB and back again should be lossless if done properly.
    John's box does the sync strip job. It's the chap to get as Mr Crow suggests.
  8. The Nightfly
    The Nightfly
    Aug 31, 2002
    801
    The New Frontier
    +23
    Excellent responses guys. I'm clear on that now.
    Allan
  9. TheCrow
    TheCrow
    Jul 16, 2004
    613
    28
    London
    +49
    If you a feeling adventurous you could build your own here.
    I thought the Sky transmissions were in RGB format and that DVD was component to save space on the disc? Not too sure on this though.
