Pioneer 43HDE DVI/HDMI connection
Discussion in 'Desktop & Laptop Computers Forum' started by netley, Aug 14, 2005.
  1. netley
    netley
    Apr 4, 2004
    118
    19
    Winchester
    Has anyone got a DVI/HDMI cable working from a MC (in my case an Elonex Artisan) into a Pioneer 43HDE?
    If so Id really appreciate a low down on the settings etc-it just wont work for me
    I can get a VGA/VGA connection but nothing out of the DVI port
    THanks
  2. TheCrow
    TheCrow
    Jul 16, 2004
    597
    28
    London
    +41
    I have no direct experance of your setup but my first thoughts would be to check what resoltutions at what refresh rate the 43HDE will accept on its HDMI port (should be in the manual).
    My guess would be that it is expecting a video resolution like 1280x720@50Hz, whereas a computer res' would be 1280x768@60Hz.
    I don't know what graphics card is in your HTPC but if it has an option for 720p give that a try. Otherwise you could try Powerstrip to force that resolution.
    Good luck
