pioneer 436xde
Discussion in 'Plasma TVs Forum' started by kully, Jun 30, 2005.
  1. kully
    kully
    Below is some info on the new pio due october, taken from av land
    Pioneer PDP436
    2x HDMI (High-Definition Multimedia Interface) Digital Link for direct connection to HDMI enabled devices
    New Pioneer Plasma Panel Technology
    Future-ready for High-Definition TV
    New Direct Colour Filter
    Reproduction of 9 billion colours
    New media receiver design
    Digital Terrestrial ( FREEVIEW ) & Analogue Tuner
    Frequency rate (75/100 Hz)
    Electronic Programme Guide (EPG) NexTView
    Mpeg Noise Reduction
    Child Lock
    Dual Screen Display
    Colour Temperature Adjustment
    Built-in Amplifier for Optional Speakers
    Large 50-inch Screen
    160-degree Viewing angle
    PC Input with XGA resolution
    Energy Save Mode and Auto Power Off
    2100 page teletext memory with level 2.5 support
    3 Line Digital Comb Filter
    MPEG Noise reduction
    Digital CTI (Colour Transient Improvement)
    Picture in picture
    25 Languages
    99 Preset Channels
    PAL & NTSC Progressive Scan Compatible
    PC Card Slot
    Dolby Digital Bitstream Output for future proofing
    Optional Products
    Pioneer PDSP-1
    Digital Sound Projector
    Supra HDMI Cables
    Specifications for the Pioneer PDP436XDE
    Screen Size 43 inch
    Aspect Ratio 16:9
    Number of Pixels 1280(Hor) x 768(Ver)
    Brightness 1000 cd/m2
    Contrast Ratio 1100:1
    Viewing Angle more than160° (Hor/Ver)
    3 Line Digital Comb Filter PAL/NTSC-M (Main & Sub)
    Video Signals PAL/SECAM/NTSC3.58/NTSC4.43/PAL60
    Inputs Input 1 : SCART RGB IN, TV OUT
    Input 2: SCART, S-Video, Component
    Input 3: SCART, HDMI, RGB SCART, S-VIDEO, Composite
    Input 4: S-Video, Composite
    PC,
    Outputs Monitor: S-Video, Composite
    Headphone
    Digital audio out (optical)
    PC Signals VGA/SVGA/XGA/Wide XGA
    Power Consumption (Standby) ???W (1W)
    Power Requirements 220-240v,50/60Hz
    Dimensions (Display) Width ???mm
    Height ???mm
    Depth ???mm
    Dimensions (Media Receiver) Width ???mm
    Height ???mm
    Depth ???mm
    Weight ???kg Display
    ???kg Media Receiver
