Pioneer 436XDE - Jerky scrolling / movement problem?
Discussion in 'Plasma TVs Forum' started by Dazza Cole, Mar 22, 2006.
  1. Dazza Cole
    Dazza Cole
    Apr 23, 2004
    1,095
    Palm Jumeirah, Dubai
    +21
    Noticed this for the first time on the rugby on saturday, that there seemed to be some elements of the picture jerking slightly when scrolling - like when motion occured there seemed to be a missing frame or 2 before "catching up".
    I also noticed last night the same sort of thing when watching sky sports news. The scrolling panel along the bottom of the screen would sometimes appear quite jerky, before reverting back to a smooth scrolling motion.
    Is this to do with the I/P setting? I've got it currently set to the middle option for the sky input, with truecinema set to OFF.
    Any ideas?
  2. GavTNewbie
    GavTNewbie
    Sep 11, 2002
    247
    Cumbernauld
    +33
    yep, i think its a common issue - both my mates and my 436xde (jan 06 and october 05 builds respectively) also do this - most notably on sky sports news. as far as im concerned its not a fault, or anything to do with user settings, just something to live with...
  3. Bacus
    Bacus
    Dec 30, 2004
    8,995
    Close to the sea
    +2,925
    Its probely more to do with the signal from sky and not your screen !!
  4. Dazza Cole
    Dazza Cole
    Apr 23, 2004
    1,095
    +21
    Ta - I hadn't noticed it on DVDs or the 360.....will have a play around with some of the settings and see if it makes any difference
  5. lunddal
    lunddal
    Feb 21, 2006
    27
    Try and set it to 100Hz.
    But I wonder if some of it has something to do with the original signal being interlaced?
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Every one I've seen does this. It's not apparent on every plasma or TV, it's the Pios that do it. I think they do it with all sources, it's most noticeable with scrolling text. As it's rarely a problem, I think most owners get so used to it they are oblivious, it would only occasionally affect your viewing pleasure after all.
  7. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    This is one of the reasons why I didn't get a Pioneer. I saw it on a 506XDE with both an Arcam DVD player and freeview and found it distracting.
  8. lunddal
    lunddal
    Feb 21, 2006
    27
    Yes, I only see it with fast horizontally scrolling text - not much of that in movies ;)
  9. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    Have you tried turning PureCinema mode off?
  10. Canalsman
    Canalsman
    Jan 10, 2006
    Macclesfield
    I was reading a review on www.homecinemachoice.com today - here John Archer writes:
    'The 436XDE's pictures are nearly flawless. The only negative point is that motion can look a bit stilted if you don't take care with the TV's many different progressive/scanning options. But it is just a matter of setup, not an inherent unfixable problem.'
    Does that shed some light?
  11. Dazza Cole
    Dazza Cole
    Apr 23, 2004
    1,095
    +21
    Thanks guys, Purecinema is off - I think it may be something to do with the interlace/progressive setting. I'll also try switching between 75 and 100 hz
  12. jayjayw
    jayjayw
    I had a full demo of the 436 at Sevenoaks and the horizontal jerking was horrendous even with top of range upscaling ARCAM DVD player through HDMI. I would have thought they had it set up correctly as it was in a dedicated viewing room with all their high end kit etc. I would love to know if there is an easy fix for this or if it is an inherrent problem???
  13. yorkyred
    yorkyred
    Oct 30, 2005
    373
    +39
    Never take for granted that any piece of kit is set up correctly,frankly many staff can't be bothered to go though all the set up options and tweaks.
    Why do you think so many flat panels look so bad in shops.
    And hi-fi dealers can be just as bad.
  14. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    100Hz is best usually, that's then as good as it gets. Still jerks a bit, but not too intrusive.
  15. THERAAAVEN
    THERAAAVEN
    Jan 31, 2006
    587
    ruislip
    +10
    Turning Off The Pure Cinema Mode Should Get Rid Of This As It Is A Featurwe That Is Always Turned On In The Settings On All Av Channels - Designed Foe Movies So Pioneer Say But Yes It Is Annoying Blur!
  16. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Are the pubs open that early on a Thursday?
  17. Dazza Cole
    Dazza Cole
    Apr 23, 2004
    1,095
    +21
    well switching to 100hz (purecinema was always off) has really helped a lot :smashin:
  18. alistaln
    alistaln
    Feb 21, 2006
    324
    46
    Reading
    +181
    Check the FAQ for more (see my sig).
  19. Blue Triangles
    Blue Triangles
    Sep 19, 2005
    1,002
    +81
    I remember reading a post of a reply from Pioneer regarding this issue that stated it was just a side effect of their plasma's! Wonderful side effect Pioneer! It really annoys me when playing my 360 on my 506, fast camera movement in 3-D games (most 360 games are 3-D) gives me a headache and makes my eyes water.
    I shall think twice when buying a plasma from them next time out, I play alot of console games you see. Does anyone know if it's to do with FRC? I think a panel will suit me better next time!
  20. Dazza Cole
    Dazza Cole
    Apr 23, 2004
    1,095
    +21
    Panzer - I don't have any problems on my 436 with fast moving games. Lots of PGR3, Quake, Condemned sessions..... Have you got Truecinema OFF though? And are you playing at 720p or 1080i ?
  21. Blue Triangles
    Blue Triangles
    Sep 19, 2005
    1,002
    +81
    If you don't notice any camera issues I won't elaborate to much on it, just incase it does become an issue for you and you blame me. ;)
    True cinema is off, I've tried both 720p and 1080i and notice it with both.....
