Pioneer 436XDE 75hz/100hz ?
Bacus
Hi all i have done a search but could not find the answer to this !!
I an just setting up my new Pioneer 436XDE and i seem to recall someone saying that you can switch between 75hz and 100hz with this screen ? If so where do i find this ? :lease:
Bacus
drguptagaurav said:
hi you can do that on the option on main menu.then drive frq.
Can I ask you what difference that makes to PQ???
gaurav
So i heard it is suposed to stop any jaggid edges in/on fast panning shots if set to 100hz !! :smashin:
Bacus
gaurav
What are your settings for your pioneer while running in ?
Dom996
I can't remember which way it goes, but one works better for telly (especially moving text like news channels) and one works better for movies.....generally.
drguptagaurav
I have noticed the same problem of lines on moving text but couldnt notice any difference with 75 or 100
I have
contrast 22-25
brightness -2 to -4
colour -10 to -12
sharpness -2 to -5
Pure cinema off
all other proadjust settings as factory
I find these nice otherwise as well. I might increase contrast and brightness a bit after running in but these settings decrease any PQ blemishes as well
gaurav
Mike Groves
What Hi-Fi recommend 100Hz for TV & 75Hz for DVD. They did not specify why though.
Mike.
