Pioneer 436 XDE run in settings
Discussion in 'Plasma TVs Forum' started by Mikeyd1963, Mar 10, 2006.
  1. Mikeyd1963
    Mikeyd1963
    Jan 17, 2006
    425
    2
    WORTHING
    +5
    Hi My 436 has been running for 343 hrs now, so im looking for changing my settings. I looked back at some old threads from27-10-05 and noticed some ISF settings as follows HDMI, colour-0. contast 34. brightness 0. Pro adjust settings were, dnr off. dre off . Blk level on. cti off. gamma 3. acl off.
    It was also said that pure cinema was set to adv, but when I try to use this setting the tv says that setting can not be used.
    Any ideas.
    Thanks........ Mike.
  2. Dom996
    Dom996
    Jun 3, 2005
    1,061
    +29
    Maybe that setting is embedded in the built in passworded ISF calibration section.
    Copying someone elses ISF settings will most likely not work, as these are set to the other persons equipment and local ambient light etc. I'm sure Piers and others will back this up.
  3. Humph
    Humph
    Sep 18, 2005
    52
    Liverpool UK
    How can you tell how many hoursd the Pioneer has been running?:confused:
  4. Dom996
    Dom996
    Jun 3, 2005
    1,061
    +29
    Look in the service menu. Access instructions are, I believe available on this site. If not google it.
  5. fidelityutensil
    fidelityutensil
    Mar 9, 2006
    28
    Just a quick one, I know they are on the site somewhere, but can't get my search to narrow down, what settings did you use for running in?
    Are there definative ones to use?
  6. Humph
    Humph
    Sep 18, 2005
    52
    Liverpool UK
    Many thanks, Dom. That's a useful facility. I'll have a look today.
    Humph
  7. Dom996
    Dom996
    Jun 3, 2005
    1,061
    +29
    Like I said the settings are appropriate to the environment. I would say for the run in period, back the brightness and contrast levels off as much as you can find acceptable, then after about 400 hours bring them up to your preferred levels. Ideally get it ISFd, it's really worth the money.
  8. ChildOfRarn
    ChildOfRarn
    Feb 3, 2006
    349
    46
    Chatham, Kent
    +126
    Mike,
    With reference to the 436 instruction manual (page 34).
    Trevor
  9. fidelityutensil
    fidelityutensil
    Mar 9, 2006
    28
    Thanks Dom,
    I'm definitely gonna get it ISFd, do i have to wait til i've done my 400hrs run in before its worth it?
  10. Reaperman
    Reaperman
    Jan 8, 2005
    636
    Stroud, GLOS
    +28
    In a nutshell...............
    YES..........
  11. fidelityutensil
    fidelityutensil
    Mar 9, 2006
    28
    Thought so.....
    ....thanks alot!:)
    Tom
