Pioneer 435XDE w/ Denon 2910 & Pioneer 1014
Discussion in 'Plasma TVs' started by bix, May 24, 2005.
  1. bix
    bix
    May 24, 2005
    356
    Manchester
    +7
    Been using AVF for advice for a while but never posted, I am looking at getting the following system for my new lounge but before I do, I'd like to see what other board user's experiences are with the equipment used together.
    Pioneer 435XDE Plasma
    Pioneer 1014 AV Receiver Amp
    Denon 2910 DVD Player
    B&W FPM 4 Speakers for Left Centre and Right
    B&W FPM 2 Speakers for Surround
    Sky
    I would be using the Denon via HDMI
    Really looking to find out about the following issues I have spotted from my searches:
    Motion Blur/Stutter
    Lip Sync (I know the 1014 has no correction for this) with Sky/DVD
    Image Quality
    Scaling (From what I know, the Denon outputs at 720P very well)
    Any suggestions are very welcome!
    Thanks a lot.
  2. Blingtastic
    Blingtastic
    Come on all you people with the knowledge. Answer the man. Please!!!
  3. wannabeav
    wannabeav
    Only advice I can offer is check out in person. I started by asking questions and got a lot of very helpful advice but nothing compares to seeing it in the flesh. Personally I liked the Pio picture and its looks but found it a little grainy compared to some. Others on here have had problems with motion, again check a screen out and see what you think. Other thing though, the amp isn't quite in the same league as the others. Probably still good but others might fit better and offer audio delay.
  4. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,133
    63
    Andover
    +110
    I think you main issue will be with lip synch from sky and your sky connection. The pio is very unforgiving on poor quality feeds. How do you intended to connect your sky system in terms of video and sound connection?
