Pioneer 435xde settings
Discussion in 'Plasma TVs Forum' started by steve0, Mar 24, 2005.
  1. steve0
    steve0
    Sep 11, 2004
    762
    Loughborough
    +32
    :thumbsup: :thumbsup: Im getting it tommorrow can anyone give me any good setting to use, I will also be connecting a panny s97 dvd player via hdmi what shall i set the players output to. Also is it worth forking out for a top quality HDMI lead or should i stick with the one I got with the player after all its only 0s and 1s
  2. steve0
    steve0
    Sep 11, 2004
    762
    Loughborough
    +32
    anyone
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,039
    I'd set the Panasonic to output 480p/576p to start.
    Set MODE on Pioneer to USER: Set contrast down to around 10-20ish.
    Make sure POWER features are off (I think the off setting is Standard or something liek that)
    Set ColourTemp to MID or LowMid
    Turn off all Noise reductions and enhancements in Pioneer advanced settings.
    Adjust brightness and colour to suit. Usually find colour will be turned down to -6 ish. Brightness probably around 0.
    Then start saving and get me around to calibrate it all properly in a month or two....hahahahaha...have fun!
    Gordon
  4. goatlips
    goatlips
    Nov 22, 2004
    272
    Croydon
    Gordon,
    I have a pioneer 434 and it's now 1 year old. Can you please give me a price to have it calibrated?
    Thanks. :smashin:
    QUOTE=Gordon @ Convergent AV]I'd set the Panasonic to output 480p/576p to start.
    Gordon[/QUOTE]
  5. Eitzel
    Eitzel
    Nov 3, 2004
    663
    46
    Top Secret-Anyone coming anywhere near my Pioneer
    +145
    Gordon calibrated my 435XDE last month. What a difference. Start saving guys. It's worth every penny! :smashin:
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,039
    Flat fee of £250. You can email me direct for info on my next trip and when I'm next down or up to your neck of the woods.
    Gordon
  7. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    Gordon,
    I've asked this before but never received an answer :
    Once its been calibrated is that it for life, or does it need tweeked every so often?
  8. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,039
    The calbration is of the display chain. So if you ditch all your sources and get new ones it might....and I mean might...require tweaking. As we start to move towards digital sources I think it less likely.
    Also with phosphor based devices like plasma I'd suspect that the RGB phosphors will wear unevenly. Of course it might be that for this to actualy make a visible difference to the greyscale it could be 10,000hrs use....(that's a guess incidentally) but until someone who has had theirs calibrated racks up some huge hours we're not going to know.
    Gordon
  9. PioRow
    PioRow
    Jan 28, 2005
    848
    +19
    Gordon, how much does the equipment you use to ISF cost? I assume you use some sort of light reading equipment that hooks upto your laptop?
  10. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,039
    I use a thing called a spectroradiometer combined with some funky software to provide a GUI for understanding what it's measuring. Just now it's $3200 plus shipping duty and VAT. You also need to understand what it is your doing of course.....it's a bit like going and buying a SNAP ON toolkit....you still aren't a mechanic.....
    I started with a thing called a tri-stimulus device from another manufacturer. That was about £1200 three years ago. Then I got another from my current supplier about 2 years ago...before upgrading to the unit I now use.
    Gordon
