Pioneer 435XDE - setting up scarts?
Discussion in 'Plasma TVs Forum' started by The Golfather, Apr 7, 2005.
  1. The Golfather
    The Golfather
    Apr 4, 2005
    401
    +8
    I have just bought a Pioneer 435XDE.
    Just need some ideas on how to setup.
    I have the following AV components:
    Pioneer 435XDE Media box and plasma (Scart sockets 1(RGB), 2, 3(RGB))
    Pioneer 545 DVD player (2 scarts)
    Sony 1070DB receiver
    Sky Box.
    I do not have components so will be using scart connections.
    I was thinking of connecting like this:
    Scart from Sky to Scart1 socket of Media box
    Scart from DVD to Scart3 socket of Media box
    Co-ax from DVD to Sony
    However you could also loop the Scarts as well so as not to manually flick through different Video inputs on the Media box:
    Scart from DVD to Sky
    Scart from Sky to Scart3 socket of Media
    - Or the other way round.
    Obviously I want the best possible solution for quality, so which
    setup would you guys recommend? And also, are there other possibilities?
    Thanks in advance
  2. Kier
    Kier
    Nov 21, 2004
    Reading, UK
    +3
    Don't loop your DVD scart through the Sky box - it won't retain RGB.
    If you want to chain your components it would be better to connect Sky -> DVD -> Media Input 1.
    However, any amount of chaining will degrade quality to some extent, so I'd go with your original plan of Sky -> Input 1 / DVD -> Input 2 or 3
  3. VIK AD
    VIK AD
    Your original plan sounds like the optimum solution.
    Reduce loop throughs to avoid loss in picture/sound quality, as resistance in cabling will be a factor.
    Use good quality cables/connectors - IXOS, Van Der Hul, QED, etc. In fact, I bought a great quality Co-Ax for audio from Maplin, called THOR - actually beat IXOS in WHAT HI tests and is on par with Van Der Hul.
    Best of luck :smashin:
  4. Golfather
    Golfather
    Mar 1, 2005
    3,066
    71
    Northants
    +95
    Like the nik mz!
  5. Golfather
    Golfather
    Mar 1, 2005
    3,066
    71
    Northants
    +95
    So, which option did you go with as I have the same dilemma now!
