pioneer 435xde problem with freeview
Melchizedek
i turned on the tv tonight to watch e4,and the picture was flickering then lost the signal,now when i try to watch dtv i get this message:this is an invalid operation because there is no channel table in dtv. i tried going to digital tv set up in the menu but nothing appears once i press dtv setup,could the media box be at fault? :mad:
btw analog tv is fine
6022tivo
I am having problems on my freebox tonight, and yesterday. Intermittent.
Winter Hill transmitter , north west Eng?
Melchizedek
it's the first major prob i've had with dtv
pontop pike transmitter- north east england
brownd
My 436xde did this, froze up completely on DTV - it's something to do with E4. I cured it by pulling the mains plug out of the media box for a few minutes
Neil Fellows
....and hear was me thinking it was just my Pio last night, how glad am I now I know it's not the media box?! (hopefully).
BurgerUK - I had the same problem exactly - I tried to scan for new channels but when I selected the DTV setup the screen went black, and that was the end of that. I turned it off at the plug, waited a few seconds, turned it back on. It then asked me for the time and date (call me crazy, but don't these things have internal batteries for that kind of thing?) I put the date stuff in, then it went into automatic installation. It found all the channels (in a new order).
Watched the TV for about 20mins, flicking through the channels when the 'invalid operation DTV table' message thingy appeared again, and I was back to square one again.
Anyone sorted this yet? And does your Pio ask for the time / complete installation procedure when you turn if off at the plug for a moment?
Melchizedek
i pulled out the mains lead at the back of the box and left it for 5 mins,put the plug in,turned on again,e4 briefly appeared then back to square one :mad:
i rang the dealer who supplied it and he's trying to sort it,said he'd be in touch this afternoon,i'll update then
Melchizedek
had mine unplugged for 3 hours tonight,when i put the plug in and turned on,e4 appeared briefly,then back to blank screen,dealer said he had phoned pioneer but couldn't get through so left voicemail,also said he was going to try and get a replacement 435xde box,said pioneer would otherwise send out engineer to remove and repair box,apparently they don't repair on site,only swapping within 28 days,so i'll have to wait and see :confused:
Rcww
I'm having the same problem and thought my 435xde was playing up until I found out it was a general problem. I found a quick fix on the net (as I dont want to miss Lost on E4 :) ) just switch on the subtitles on any channel other than E4 and then switch to E4 and you should be able to view it without any trouble. Hope it helps
Regards
Moosh
Hi all
I had the same problem a few days ago:
http://www.avforums.com/forums/showthread.php?t=254517
And last night the channels locked again. So I switched off the plasma screen + box at the mains, switched it back on, turned the screen on and then went straight to Setup > DTV Setup > Software Update > Start Manual Update. Once this had completed then Setup > Auto Installation > Start. That got everything working again.
Moosh
Neil Fellows
Still having trouble last night - now my TV will not even attempt an auto install to set up DTV again. To make matters worse, it will no longer swap inputs either (numbered 1-4 on top of remote) so I can not use my Pace Twin digital box for TV. I find it difficult to think that a simple freeview re-shuffle caused all this.
Anyone elses playing up still?
Melchizedek
queer thing i'd almost given up,then i turned it on about 30 mins ago,and hey presto i've got dtv again :D ,i've done a channel scan and replaced the channels,the epg and channel order doesn't agree quite with that on digital spy as posted by others :thumbsup:
Neil Fellows
Hhhmmm... I've just spoke to my Pio dealer who confirmed there is a problem with freeview, and will let me know in the morning what is happening after they have spoken to Pioneer.
Melchizedek
my pioneer dealer is still insisting on replacing the box,he claims he cannot get through to pioneer-they're so busy he gets the message all agents are busy please call later,also he tells me the rep is on holiday!,fine company pioneer if they're unobtainable,or maybe my dealer is a bull****ter :(
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
