D
duncan_smith
Help.....
I have owned my Pioneer 435XDE since April. Fantastic bit of kit. I have had it connected to my Pi 868AVI-s via HDMI for ages.
Last month moved the Media box to dust underneath and the HDMI connector no longer works. Taken to a service centre locally, they have diagnosed the Printed Circuit board has a hair line crack in. This is NOT covered under the warranty as it is classed as "User Abuse".
A bit worrying as the centre bit of the HDMI socket (that bit were the pins make contact) are part of the main circuit board.
£500 to fix.
Does anyone know if this has happened before? I am trying to convince Pioneer UK that this is a design fault with the box. This connection should not break from a little movement. Scart leads take oodles of punishment.
If anyone has a suggestion or a route that I can take please help
£500 to fix.
