Pioneer 435FDE Buzz
Discussion in 'Plasma TVs' started by Desmond, Jun 7, 2005.
  1. Desmond
    Desmond
    May 31, 2005
    406
    +7
    Evening Everyone,
    I purchased a Pioneer 435FDE about a week ago and am very pleased with however there is an annoying buzzing sound that can be heard only if I sit straight in front of the display, if I move a foot or more to the left or right then the buzz becomes less audible.
    Has anyone else had this problem or know of a cure.
    Thanks in advance
    D
  2. bigmac1
    bigmac1
    Sep 26, 2004
    89
    London
    I have the XDE and there is a buzz from it although I only notice it when I have the sound muted. There are a few threads on here which cover various people issues with buzzing from Pio's. Some people seem to find it worse than others? Other people have said that it seems to reduce after the first 200 hours? I don't think it should be audible during normal viewing so if it is bothering you it might be worth getting an engineer out to check it to see if they consider it acceptable?
  3. Desmond
    Desmond
    May 31, 2005
    406
    +7
    Cheers Bigmac,
    I will get someone to come and check it out.
    D
