Pioneer 435-xde Power problem!
ngenius1
Hi guys, screen has just decided to switch itself off while watching the football!! Disconected everything and tried to turn it back on, same problem. You turn it on, the red light flashes and it shuts down.
Anybody had similar problems?
thanks for any help you can offer.
ikon66
haven't had that problem but I presume you have checked the connections in the back of the panel and the media box???
llanellijack
No, my 434 HDE does it. If my SKY+ box is powered on and then I try to switch my plasma on, the plasma shuts down. If I switch my plasma on first then power up my SKY+ box, no problems. Pionner say they are aware of the fault which I think is attributed to a faulty control board.
ngenius1
Thanks for the response guys,
Cant get into the menu, as soon as the screen turns on it shuts down.
Left it over night still the same.
Will se how many times the light on the media box flashes and let you know.
Thanks again.
ngenius1
Led on the monitor flashes 6 times then 7 times continually after.
You can still switch on the media box via the remote even while the screens flashing the led!
llanellijack
If your using SKY then try using a different scart input on your media box / plasma to connect your SKY box. Does the problem still persist ?
ngenius1
Goes into shutdown with nothing connected to it!
Gone to the repair centre now, will let you know the outcome.
Thanks all for the response. :thumbsup:
