Pioneer 435 XDE - Advice Apperciated
Discussion in 'Plasma TVs Forum' started by stormorbit, May 15, 2005.
  1. stormorbit
    stormorbit
    Hi Folks,
    I am about to order the Pioneer 435 XDE, The question is which cables do I need to buy with it. I have the new Cambridge DVD player (Not a recorder) and a JVC video recorder (OK it will be replaced shortly but thats what I have at present) I would appreciate some advice on which cables/leads to order with it.
    Thanks in advance..... :)
  2. MPK
    MPK
    Nov 26, 2004
    478
    London
    +8
    I don't think the Cambridge DVD has a HDMI or DVI out, so you'd want to get a component video cable (i.e. three separate cables for YPbPr). For the video recorder get a scart cable and if you have a sky or cable box another scart cable. I'd use all high quality cables, around £30-50 each. For the audio I'd get an optical digital cable between the DVD and the media box. The VCR's audio will be in the scart connection.
  3. stormorbit
    stormorbit
    Thanks a lot for the advice, I will go down the road you suggested...
    Cheers!
