Pioneer 435 speaker choice
Discussion in 'Plasma TVs Forum' started by jrturbo, Jan 22, 2005.
  1. jrturbo
    jrturbo
    Hi there guys
    I have just ordered a pioneer 435 xde and should arrive next week but i have not ordered the optional speakers, although I have home cinema set up, i wanted to purchase some speakers that are availabe for this screen in order to avoid switching the whole av amp setup ( the other half gets stressed when she presses the wrong buttons on the remotes, etc )
    So the question is there a noticeable difference in sound quality between the silver speakers which can be placed under the screen or on the sides, or the black ones with are only suitable for instalation on the side but apear larger and adjustable in orientation.
    Regards
    Joe Rubido
  2. jaguar
    jaguar
    Nov 17, 2004
    186
    I think it is just the looks.
  3. jayk
    jayk
    Nov 21, 2004
    11
    both speakers are identical in spec
  4. cucuz
    cucuz
    Jun 16, 2004
    123
    +6
    The only difference is in the length , ie. the black ones are longer so there might be a slight difference in sound , but as with pictures where your eyes are the best judge , have a demo and let your ears decide .
