Pioneer 435 FDE and xBox 360 problem
osmononame
Hi,i have recently bought a xBox 360 for use with my Pioneer TV, i have it hooked up via the component cable and the picture quality is amazing, however, i cant seem to get the sound to work, when hooked up through the front ports the sound works but obviously it isnt hi-def. Is there anything i could be doing wrong or are my sound ports dud?
chaparral
You need to feed the audio in to the number two scart input on the rear of the pioneer media box when using the component input for video..
Warpaint
The component input doesn't have separate audio inputs. If you connect the left and right audio from the X-box to the scart socket with the same AV input number as the component (AV3 I think) then you will get the sound.
A scart adaptor with phono sockets on it will do.
cboy
u also need to set it to optical out or sterio in 360 settings
