Pioneer 434HDE - " Smearing"
Discussion in 'Plasma TVs' started by dixiedean, Nov 29, 2004.
  1. dixiedean
    dixiedean
    Nov 25, 2004
    41
    I have had my Pioneer 434 a while now and have noticed that on some channels ( not all), there is a bad smearing effect, for want of a better description. DVD's are superb, but the Sky pix are sometimes awful and unwatchable. I have the Sky on input 1 RGB and DVD on input 3
    (component).
    Anyone else experienced this problem and if so , any advice?
  2. hutters
    hutters
    Aug 20, 2003
    710
    28
    Cambridgeshire
    +28
    I was initially disappointed with the pic I was getting from my NTL box, but after playing around with the menu options and switching off (or down) the 'auto' processing the screen did I ended up with a picture that I'm quite happy with. Have a play, you can always reset the defaults.
  3. jaguar
    jaguar
    Nov 17, 2004
    186
    I know what you are talking about.
    It seems that it depends on the quality of the signal input.
    I just saw it on an old MASH rerun. It look like the screen suffer huge lag.
    I haven't found any setting to circumvent it.
    What is meant with 'switching the 'auto' proccing down of off' :confused:
    By the way I own a 435.
  4. Jedster
    Jedster
    Aug 4, 2003
    12
    Hampshire
    I think what is meant is to switch off the DNR and the MPEG Noise Reduction. I have DNR "off" and always have had on all large TV's and the MPEG Noise Reduction set to Low (435XDE)
    This certainly looks better...hope thats of some help
  5. dixiedean
    dixiedean
    Nov 25, 2004
    41
    Thanks guys. I have switched everything to the Low setting and DNR to off and it seems a bit better. The main culprits are the History and Doc channels, especially on Forensic Files for some strange reason.
    All I need to do now is replace my Jamo DVR50, which has so many niggling faults, with a more reliable player! :)
  6. jaguar
    jaguar
    Nov 17, 2004
    186
    You beat me to it.
    :rotfl:
    I have the same results.
  7. astirling
    astirling
    Oct 1, 2004
    800
    28
    Dunfermline
    +44
    They look utter rubbish on my 32" phillips widescreen tele. They're just a blocky mess.
  8. dixiedean
    dixiedean
    Nov 25, 2004
    41
    Quick update - The "smearing " has all but disappeared with the new settings, hardly noticeable now.
    If only I could sort out the pic during a footy match!!
    Thanks again guys
