pioneer 434
Discussion in 'Plasma TVs' started by goatlips, Nov 26, 2004.
  1. goatlips
    goatlips
    Nov 22, 2004
    270
    Croydon
    On the top right hand of the screen when switching inputs it says RGB 625I. Can you please tell me what 625I means?
    Thanks.
  2. ian harland
    ian harland
    Hi, it simply means you have set your scart inputs to the media box, as RGB.
    625i = 625 lines interlaced.
    Make sure that you make input 1, your connection to your sky box.
  3. jwramsay
    jwramsay
    Sep 7, 2004
    1,615
    West of Scotland
    +69
    Whats wrong with Input 3?
  4. goatlips
    goatlips
    Nov 22, 2004
    270
    Croydon
    I have my sky on input 1 and DVD on input 3. Can I get it higher than 625I on Sky?
  5. jwramsay
    jwramsay
    Sep 7, 2004
    1,615
    West of Scotland
    +69
    Not yet, but in 2006 Sky will be breadcasting in High Definition. (HDTV)
    You'll then get 720p or 1080i, depending upon which format Sky choose. You'll also need a new Sky box with Component outputs and/or HDMI.
