Pioneer 434 Picture flicker
Discussion in 'Plasma TVs Forum' started by Quinny, Jul 6, 2004.
  1. Quinny
    Quinny
    Apr 19, 2004
    91
    Cambridge
    I have had my Pioneer 434 up and running for neraly 2 weeks now and am really enjoying it. The PQ is excellent and as has been said by many here, the quality improves daily.
    But, and there's always a but, I have noticed a slight change in the picture brightness occurring from time to time. It is more noticeable on light scenes but the picture can be seen to get slightly darker and then almost as quickly go back to the same level again. This happens on RF, DVD and SKY+. Both the DVD and SKY+ are connected via RGB into Input 3 on the Media box. The change is very quick and can happen at any time, albeit not that often.
    Is this a fault or merely a 'characteristic' of the screen (either Pioneer or Plasma in general)? I have adjusted the contrast and brightness down during the running in period but adjusting this during tinkering sessions doesn't have any impact on it.
    As I say this is very sporadic and my wife hasn't noticed it, but I would love to find out why this is happening. Can anyone help?
  2. LeeT
    LeeT
    Mar 24, 2004
    77
    Derby
    I have a 504HDE but don't have this problem. I suggest that you should move your inputs around and have Sky+ on AV1 via RGB and then your DVD player on AV3 as Component if possible. As this is the best way to connect unless you have a HDMI dvd player.
  3. Quinny
    Quinny
    Apr 19, 2004
    91
    Cambridge
    LeeT
    Thanks for the reply. I understand your point of view but I have to have it set up this way as I am passing SKY+ through a DVD recorder. SKY+ is passed though the DVD into AV3. This still allows me to re-configure AV3 to Component when I watch DVD and change back to RGB when SKY+ is used. I am considering using the S-Video output from SKY+ and putting this into AV2 and using AV3 as the DVD input only.
  4. LeeT
    LeeT
    Mar 24, 2004
    77
    Derby
    Ah I understand now. Maybe its a signal degradation issue going through the DVD recorder! Sorry couldn't be any more help.
  5. Quinny
    Quinny
    Apr 19, 2004
    91
    Cambridge
    Thanks for trying. Unfortunately it doesn't explain why I can see it on the RF input too. Looks as if I will have to try Pioneer unless anyone else has any ideas. Anyone?
  6. Rexus
    Rexus
    I had a similar problem but it went away when I switched off the power saving mode
  7. Quinny
    Quinny
    Apr 19, 2004
    91
    Cambridge
    I appreciate your reply. I'll have a look to see if this is set to on but i'm pretty sure that I have the power saving mode off.
  8. ROBERTT
    ROBERTT
    Apr 2, 2003
    311
    +21
    Hello,
    I have the Pioneer 434HDE. The effect you describe is down to the DRE (Dynamic Range Expander). Look in the manual to see what setting this is on.....Off, High, Mid, Low. Try playing with these settings :)
    Not a problem with screen :D
  9. Quinny
    Quinny
    Apr 19, 2004
    91
    Cambridge
    Thanks Robertt,
    That's two things to chek when I finally get home. I'll keep you posted.
  10. Quinny
    Quinny
    Apr 19, 2004
    91
    Cambridge
    It looks as if Rexus was right. Turning the Power Save mode off appears to have cured the flicker. Thanks for your help.
