Pioneer 434-HDE and Pronto Pro CCF
Discussion in 'Plasma TVs' started by Josh_P, Jan 14, 2004.
  1. Josh_P
    Josh_P
    Think the title says it all, but has anyone produced a Pronto Pro CCF file for the Pioneer 434-HDE Plasma, and would be willing to share it with us?
    Have looked on RemoteCentral but have had no luck finding one.
    I don't have my 434 yet otherwise I would learn the codes myself and was hoping to get a jump by already having my Pronto programmed before it arrives.
    Any help would be much appreciated.
    Regards
    Josh
  2. bryeden
    bryeden
    Nov 20, 2003
    30
    Jersey
    +3
    Josh
    I used the only plasma display listed under Pioneer on RemoteCentral the model is shown as PDP-503CMX - it works well for my 504.
    I think the codes are the same as the 434, certainly worth trying
    Regards
    Bryan
  3. Josh_P
    Josh_P
    Cheers bryeden
    I'll give it a try
    Josh
  4. Messiah
    Messiah
    Apr 22, 2002
    7,529
    +339
    I have extracted just the plasma device from my ccf and you can get it here
    Enjoy.
  5. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    I made one up whilst waiting for my 504 to be delivered... I cancelled the order so never got hold of the remote, the .ccf just needs the codes added...
    PM me if you want a copy... I'm sure someone could make good use of it..!
  6. Josh_P
    Josh_P
    Cheers Simon
    But it's the codes I was really looking for.
    Regards
    Josh
  7. funkin
    funkin
    Jan 28, 2003
    41
    London
    Yeah, the ones from remotecentral worked for me on the 434.
  8. Messiah
    Messiah
    Apr 22, 2002
    7,529
    +339
    Josh
    The codes are in the ccf file I linked to above. No good?
  9. Josh_P
    Josh_P
    Sorry Messiah
    Yeah, they were a great help, i downloaded them at work but couldn't reply.
    Thanks for your help
    I will use them to make up my CCF.
    Regards
    Josh
