Pioneer 434 Component question
Discussion in 'Plasma TVs' started by Abadd, Dec 1, 2003.
  1. Abadd
    Abadd
    Possibly a stupid noob question but........
    Does the 434 only take component through Scart? This is the impression I get from the specs. If so, what lead should I use from component switchbox to plasma?
  2. Diapason
    Diapason
    Apr 29, 2003
    276
    Dublin
    +7
    No, it takes the regular 3xRCA cables. Basically, Input 3 can accept various connections, one of which is SCART, one of which is 3xRCA component, and I believe HDMI is also on Input 3. You connect whatever you want and then set up the screen to take the input from the appropriate connector.
    Si
  3. KevinWood
    KevinWood
    Dec 9, 2002
    101
    19
    Stirling
    As I was once told, "there is no such things as a stupid question, only stupid answers!", so to answer your reasonable ;) question, with hopefully not a stupid answer.
    There is one set of component inputs using RCA connectors (I think that's what they are called!) and not scart.
    Kevin.
  4. Abadd
    Abadd
    Ahh, I thought it would. I just looked at the techtronics diagram table thingy and got confused.
