pioneer 434 callibaration
Discussion in 'Plasma TVs Forum' started by jeroenskie, Jan 25, 2004.
  1. jeroenskie
    jeroenskie
    dear people.
    I have my pioneer for a while now and i want to calli... it
    is there a reason why i ust not do this?
    and does anyone know how I can enter the dealerssettings.
    I mean the menu that is not for consumers.
    hope someone has calli... it already and knows if it worked.
    kind regard jeroen
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,150
    +2,970
    The Integrator menu was removed from all 434 and 504 units specifically to stop folk who do not have software and knowledge from working on their plasmas. At present all that is open to you are the user controls.
    Sometime in next 2-3 weeks the manufacturers of calibration equipment, Milori inc, Progressive Labs and Sencore should start releasing software that will allow calibrators to use their laptops to talk to the plasma's to execute the changes required to make these devices work most accurately.
    Hope this is of use,
    Gordon
  3. jeroenskie
    jeroenskie
    thank you for the reply.
    so if i understand correctly ....
    I haven to cancell teh apointment with the calibaration guy
    he is a certified company that does it for years now...
    so it is not possible for him to do the job....???
    how can he get the info he need to do the calli.....
    hope you know..
    kind regards jeroen
  4. Senninha
    Senninha
    Dec 2, 2003
    135
    Scotland
    +9
    Thanks Gordon - can you keep us informed? My 434 will be installed soon, and I reckon I'll rack up 100 "pre-calibration" hours pretty quickly :)
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,150
    +2,970
    I'd ask your calibration guy if he's ever done a 434. If he has and says he can do the work ask him to email me how as I'd like to know. It is possible to fix some issues and do greyscale if you have an suitable external video processor in your system and route all signals though it. If everything is going direct then I do not know how you can fix anything.
    If he hasn't done a 434 and is assuming it's the same as previous Pioneers I'd advise him it is not and cancel the calibration. He should be aware of the manufacturers whose names I posted and he should contact one of them or Pioneer for further information
    Gordon
    The integrator menu is actually there it's just its full of hex code and unless you know what each bit is for and how to adjust it (and I know of no ISF or Pioneer guys who do) it's best left alone.
  6. jfraser
    jfraser
    What exactly is in the Integrator menu....I think I found it by accident yesterday.....I was trying to find an advance code for a remote control and entered the menu....It had number of hours the TV had been running for etc, was this it??
  7. Arsenal
    Arsenal
    Mar 25, 2002
    232
    London
    hmm i'd like to see how many hours my 434 has been on for (with a view to asking for Gordon's expertise at some point), any chance you could say how you got there jfraser?
  8. Ratoban
    Ratoban
    Feb 11, 2003
    130
    Coventry
    Oh cum on spill the beans, i`ve got to know how many hours its been used for :D
    Rob
  9. Gordon @ Convergent AV
    Jul 13, 2000
    14,150
    +2,970
    To enter old menu you would
    Make sure unit is OFF.
    Press "Menu" button on remote
    Then press "stby" button and it would come on with a new multi page menu allowing the same changes as user menu plus RGB cut offs and gains, sizing and positional controls and some other stuff. Hrs used was probably there too.
    Gordon
  10. gingerone
    gingerone
    Dec 10, 2002
    2,551
    +376
    Sorry to hijack your thread but I have a question for Gordon.
    I'm trying to change the overscan settings on my panasonic 37pa20 but when I change the settings in the service menu they saty at the new setings only until I come out of the menu and switch off.
    Being as you've calibrated loads of pw6's I'd imagine you'd know how to save the adjustments?
  11. Diapason
    Diapason
    Apr 29, 2003
    276
    Dublin
    +7
    Gordon,
    A quick question about the info you give above. Is this the sort of menu that will invalidate a warranty if I play with it? I'd like to reset overscan on the 434, but if there's any danger whatsoever I'm happy to wait for a professional to do it!
    Si
  12. Ratoban
    Ratoban
    Feb 11, 2003
    130
    Coventry
    Anybody tried to access the menu using the old way?
    Didn`t work for me, come on jfraser enlighten us .... please:rolleyes:
    Rob.
  13. Gordon @ Convergent AV
    Jul 13, 2000
    14,150
    +2,970
    The integrator menu wouldn't usually invalidate your warranty but I believe that with the proliferation of tweaky info on the net Pioneer sought to disable the end users ability to use it. There had been issues of damage due to misuse (in other words if you don't know what a setting does or how to adjust it safely or correctly it's best left alone). YOU SHOULD CHECK with your supplier or the manufacturer before adjusting any hidden or non user functions if you are concernded about invalidating warranties
    Gordon
    RE Panasonic. I emailed you the answer. over a day agO OR PERHAPS IT WAS A pm. It was a reply to however you contacted me though
  14. KelvinHT
    KelvinHT
    Dec 31, 2003
    330
    Kent
    +13
    just tried this on my 434, all I get is the serial config for the intergrator menu.
  15. gingerone
    gingerone
    Dec 10, 2002
    2,551
    +376
    Thanks Gordon I've read your mail now.
  16. Ratoban
    Ratoban
    Feb 11, 2003
    130
    Coventry
    Yep Kelvin got that as well, couldn`t get any further.....yet
    Rob.
