Pioneer 434 Cable and Wallmount
Discussion in 'Home Cinema Buying & Building' started by RzSwede, Feb 19, 2005.
  1. RzSwede
    RzSwede
    Hello,
    I am just about to buy a Pioneer 434XDE (the feedback and my personal experience at the shop has convinced me that this is the one to get =) and I am hoping someone out there with this plasma could give me some info.
    What I need to know is:
    1) How long is the cable connecting the media box to the actual plasma screen? (and are extensions available?) I need to place my media box roughly 5-6 meters from the screen.
    2) I am building a new wall where the plasma will be hanging, and I am ordering the PDK-WM02 wall mount, has anyone got this mount and if so - is there any way of finding out the distance between the mounting points? (I will be reinforcing the wall exactly where the screws come in from the wallmount)
    Many thanks in advance.
    Rz
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Cable is 3m, Pioneer 10m cable = £200, sharp 7m cable, identical, = £125. These are replacements, not extensions. The wall mount is a total rip off, get a wall mount for a sensible price, do yourself a favour. Loads are available for under £100, I'm sure anyone you mail order off will tell you the spacing of the mounting screws.
  3. Drd
    Drd
    Jan 22, 2005
    1,904
    Approaching the doghouse at great speed
    +301
    Hi RzSwede
    I just mounted my mxe on an AV sales slimline wallmount (see power buys).It's an excellent bit of kit fixed on each side by four screws/bolts of your choice.I had a problem with a power cable in the wall I was drilling into but this mount was great for me as the horizontal separation of the holes was 500mm.
    Ian
  4. RobbieTT
    RobbieTT
    Jan 9, 2005
    398
    +6
    7m Sharp cable?
    Sounds like you have just saved me £75 quid, so thank you. Is the cable any good, quality wise and where can I get it from?
    Didn't like the idea of a 10m cable, as I only need about 4.5m anyway. Anyone do a 5m version of this system cable?
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It's the cable Pioneer supplied up until last year, quality is fine. No 5m versions, sadly. I hope I've saved you another £150 on the bracket. There is absolutely nothing special about the Pioneer one, it's just a chunk of pressed steel like all the other cheaper ones. I don't sell the Pioneer ones on principle.
  6. RobbieTT
    RobbieTT
    Jan 9, 2005
    398
    +6
    Thanks again - I'll follow the advice on the braket too.
    Not managed to find the cable on a google search, any ideas?
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Where are you? I keep them, can post I suppose, it's not my line of business, I'm a custom installer. Email or PM if that helps you.
  8. RobbieTT
    RobbieTT
    Jan 9, 2005
    398
    +6
    E-mail sent!
  9. RzSwede
    RzSwede
    Whey, thanks for all the replies =)
    Great advice too, I'll definitely think twice about the wallmount and get a cheaper one!
    I would be very interested in the Sharp cable, 7m sounds good to me. Would you be interested in selling me one too as I haven't found it anywhere in Sweden when I looked for it? I would obviously cover shipping charges and a bit extra for the hassle.
    Drd, is that the tilting slimline wall mount you bought?
    http://www.av-sales.co.uk/plasma/html/slimline_tilting_plasma_wall_m.html
    Regards,
    Rz
  10. Drd
    Drd
    Jan 22, 2005
    1,904
    +301
    Hi RzSwede
    Yes it was,performed the hang test after putting it up,it took my weight no problem!I've mounted mine flat, but the tilting mechanism is very simple and effective.
    Ian
  11. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I guess there's nothing to stop me shipping a cable to Sweden, not exactly outer Mongolia is it.
