pioneer 434 aspect ratios
Discussion in 'Plasma TVs Forum' started by paulefox, Nov 25, 2003.
  1. paulefox
    paulefox
    Feb 8, 2003
    1,330
    Bury St Edmunds
    +44
    does thsi machine automatically change the screen ratios
  2. paulefox
    paulefox
    Feb 8, 2003
    1,330
    Bury St Edmunds
    +44
    I an get one for £3800 and they are in stock , what do you think
  3. lumpsucker
    lumpsucker
    Nov 18, 2002
    411
    Cornwall
    +15
    I believe it will switch aspect ratio automatically through the scart connection or you can elect to choose the aspect manually. The price you have found seems fair and if it's in stock then grab it quick.
  4. paulefox
    paulefox
    Feb 8, 2003
    1,330
    Bury St Edmunds
    +44
    bit worried about screen burn , is it easy to get this problem
  5. paulefox
    paulefox
    Feb 8, 2003
    1,330
    Bury St Edmunds
    +44
    it is £3769.99 to be exact but doesnt come with a stand or speakers
    I thought I could buy a bracket from the power buy
  6. lumpsucker
    lumpsucker
    Nov 18, 2002
    411
    Cornwall
    +15
    A search on Screen Burn will be rewarded with many threads to puruse. By the time you have read them all your 434 will no longer be in stock.
    Screen Burn will only occur after many hours of showing a static image. Basically by neglecting and abusing you £4K plasma. Now you ain't goin to do that in a hurry are you ?
  7. paulefox
    paulefox
    Feb 8, 2003
    1,330
    Bury St Edmunds
    +44
    do they auto switch on component and scart
  8. howies
    howies
    they will only auto switch on scart not component as 1 of the scart pins tells the tv what aspect ratio to be in.
