Pioneer 434 and 1280x720 resolution
Discussion in 'Plasma TVs' started by ggp159, Jul 13, 2005.
  1. ggp159
    ggp159
    Is there a way to force 1280x720 resolution through the vga input? If not is this resolution available when connecting a pc with DVI to HDMI cable? Thanks!
  2. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,719
    Sector7
    +844
    If you want to force any resolutions not standard within your display settings then you need to use powerstrip!
    Using the Dvi - HDMI route will give you this option in the standard settings without pwerstrip, when the graphics card detects your display!
    Dr.
  3. ggp159
    ggp159
    I have 1280*720 with the vga input when i select it though it says signal not supported
  4. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,719
    Sector7
    +844
    Thats because the VGA port (on the panel) only supports standard resolutions 800 x 600, 1024 x 768, 1280 x 768 etc... Look in your manual!
    Only the Dvi/HDMI connection will exept high resolution video formats like the 1280 x 720 which you are trying to achieve!
    Dr.
  5. ggp159
    ggp159
    Thanks Dr.HTPC and forgive my ignorance :)
