Pioneer 434 & 868i HDMI video question
Discussion in 'Plasma TVs Forum' started by KelvinHT, Jun 24, 2004.
  1. KelvinHT
    KelvinHT
    Dec 31, 2003
    330
    Kent
    +13
    When playing DVD over HDMI on my 434 from the 868 I get the status message reporting this
    868 set to 1080i 434 reports 1125i
    868 set to 720p 434 reports 750p
    Any ideas guys ?
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,522
    Kent
    +830
    Yes that is normal. You will also find 480p recognised as 525P, and 575P as 625P. The Plasma is including lines of blank information that make up the signal in it's description, the DVD player is referring to the resolution of the picture information only. It is nothing to worry about.
  3. KelvinHT
    KelvinHT
    Dec 31, 2003
    330
    Kent
    +13
    thanks for the info Liam.
