Pioneer 433MXE1 and Tivo ...no show...
Discussion in 'Plasma TVs' started by Family Guy, Feb 27, 2005.
  1. Family Guy
    Family Guy
    I have a Pioneer 433MXE1 plasma which I am feeding via my Onkyo 702 amp through an Iscan Pro. Now, the compoents I have connected are as follows:
    DVD player - component to amp
    Sky + - s video to amp
    Gamecube - composite to amp
    Everything is then "upconverted" by the Onkyo amp and fed to the Iscan pro. However, when i connect a Tivo to the amp, I get no picture. I am using the TV scart on the Tivo connected via a scart to composite lead. The Tivo scart out is set to Pal (though it actually makes no difference if i set it to RGB & Pal or Pal - still no picture). I get no picture whether I connect the Tivo direct to the plasma, to the amp (upconverted and out to the the Iscan) or direct to the iscan.
    The Tivo is outputting a picture via RF and the scart connection works as I have had them connected to a 14" portable...
    The Tivo subsciption isn't activated yet...so the Tivo technical helpline won't help me...they say if i activate the sibscription they'll offer me technical assistance but can't guarantee it'll work... :thumbsdow
    Anybody care to help me out here... :lease:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Family guy can you "borrow" a JS RGB>YUV converter and give that a go?
  3. Family Guy
    Family Guy
    That would probably work but I don't think we have any in stock...I was kinda hoping to get it working without adding to the cost as well TBH.
  4. Family Guy
    Family Guy
    ...though thinking about it, I'm already using a component converter in the amp - so maybe it won't work...:confused:
  5. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Brian, pop round and pick one up. Your amp doesn't like the composite vid, or the lead/adapter is bust.
  6. Family Guy
    Family Guy
    I'll pop round shortly...
