Pioneer 433MXE With Desk Top Stand
Discussion in 'Plasma TVs Forum' started by Paden, Apr 12, 2003.
  1. Paden
    Paden
    Jul 27, 2000
    572
    +19
    Can you tell me roughly what the distance from the tabletop to the lower edge of the screen is?
    I'm thinking of getting one of these panels & am trying to work out where my centre speaker will go.
    I was hoping to place it in front of the panel on the tabletop as well but I obviously don't want it blocking my view of the screen!
    Thanks, Paul
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,555
    The Borders
    +3,026
    Paul
    The MXE is normally supplied with the PDK-TS01 (though these have been difficult to get a hold of for a few weeks as the new PDK-TS03 swivel mount in Silver have been introduced).
    With a TS01 you dont get much room for sticking a centre channel below the plasma - the base of the plasma is set at 100mm from your table top.
    You do have to factor in that the TS01 base plate is 20mm tall and leaves a flat plate in front of the display that is 540mm x 120mm - limiting you to 80mm* clearance for your centre channel.
    We also supply pedestal stands from SMS - much more expensive but with a much greater clearance to accommodate a centre channel.
    Trust this helps.
    Joe
    *This assumes you dont want the centre channel to encroach into the line of the bezel
  3. Paden
    Paden
    Jul 27, 2000
    572
    +19
    Thanks for the reply Joe :smashin:
    My centre speaker is about 180mm & not compressible :D
    Do you have a link for the pedestal stands from SMS? Couldn't find any pictures on your site.
    Cheers, Paul
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,555
    The Borders
    +3,026
    Paden
    Have a look here http://www.sms.safebrackets.se
    Sold quite a few of these units - they are very well built and very well finished.
    Best regards
    Joe
