pioneer 433mxe & powerstrip
Discussion in 'Plasma TVs' started by whistlingDogg, Jul 1, 2003.
  1. whistlingDogg
    whistlingDogg
    Oct 14, 2002
    196
    Wokingham
    I'm trying to test out playing dvds through my pc but I can't seem to set the resolution correctly. I tried using powerstrip but didn't know what settings to use. I'm trying to use my tosh lappy which normally output 1024x768, the same res as the pioneer. The picture's at the wrong aspect ratio. To get it right I would expect the picture on the lappy look stretched so it would appear correct on the plasma.
    Any help much appreeciated
  2. Dutch
    Dutch
    Dec 5, 2002
    2,592
    3
    North Yorkshire
    +280
    Hi Dogg.
    I think you need to set the output at 1280x768 to get the picture in the correct proportion. I'm going to try my computer on my new 433MXE later tonight to check out the DVI connection. Should be awesome!
    Steve
