Pioneer 433mxe playing svcd/vcd screen keeps going blank
Discussion in 'Plasma TVs Forum' started by rsvman, Jun 2, 2003.
  1. rsvman
    rsvman
    Oct 28, 2002
    140
    16
    +3
    Just Installed...
    I have a pioneer 433 mxe connected to a denon 3802 amp (via component) which is connected to JS rgb2yuv box and then into a quintro via scart and the dvd player is connected to the quintro via scart.
    Whan i am playing either svcd or vcd's, during playback, i get the plasma screen flickering to black, but can still hear the sound, it evenetually comes back, but does hapeen quite frequently during these types of movies, which i never had any probs with a normal TV.
    I was wondering if anybody has any idea about this...
  2. Party Animal
    Party Animal
    Jan 29, 2003
    241
    +13
    as Long as your VCD etc are encoded properly they should play back fine, I have a 42" Panny and it plays everything, including crap downloaded stuff from the net
    make sure you have the correct input selected
  3. rsvman
    rsvman
    Oct 28, 2002
    140
    16
    +3
    I tried this with Matrix dvd last night and still got the same problem ??
    any ideas ??
  4. Party Animal
    Party Animal
    Jan 29, 2003
    241
    +13
    Try playing these movies via a direct connection to the plasma..instead of thru the various converters, sounds like a dodgy connection or a duff converter/cable
