Anyone got any experience of driving a 433 using DVI?
I'm trying to use one of the new Samsung DVD players in DVI mode. the player tells me it is outputting 1024/768. This stays constant whatever aspect ratio I set on the player.
The plasma is picking this up and displaying the image 4:3 with black side bars. The plasma display function tells me the image is 1280/768, which might explain why I've got side bars.
the technical manual for the MXE tell me the unit will accept both 1024/768 and 1280/768, and i had assumed that it would auto switch. It looks like this is not happening, but I can't find any way of manually changing the plasma setup, even in integrator mode.
I've had similar problems setting up PC input over VGA and for a while I could see a setup menu with XGA/Wide XGa etc, but I can't find it anymore.
I've talked to Pioneer, who were very helpful but ultimately could not help. The spec of the 433MXe talks about DVI PC signals, but not video.
Any ideas?
(I've put a similar post in the HD745 thread under DVD players)
Any ideas
Any ideas?
Any ideas
