Pioneer 433HDE Engineer Mode
Discussion in 'Plasma TVs Forum' started by Anuj, May 31, 2004.
  1. Anuj
    Anuj
    My friend has a Pioneer 434HDE and with a button combination on his remote can get into the engineer mode on his TV, I have tried the exact same combination that works on his TV on my 433 but it does not work on mine, does anyone out there know how to get into the engineer mode on the 433HDE? :lease:
    Thanks.
  2. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,191
    38
    +3
    What is the code for the 434hde?
  3. suzywong
    suzywong
    Nov 6, 2003
    261
    19
    Southampton
    :lesson: for Andynumpty
    For the 504 & I believe also for the 434
    Put the unit in standby.
    Press and hold the channel info button and wait 3-4 seconds.
    Then press left,up,left,right and then the orange button that puts the panel to standby.
    The panel should switch on displaying the service menu.
    Use at your peril!:nono: and don't blame me if you screw things up:oops:
  4. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    Anuj,
    For the 433HDE put the screen into standby using the remote then press 'menu', 'select' and 'zero' in quick succession.
    But from memory nothing much in there of any use except the usage counters.
    And be warned you could seriously :censored: things up in there.
    Cheers, Lee
  5. Anuj
    Anuj
    Loonatic, I can't get it to work, when you say select to you mean enter? I cannot see a select buttom on my remote.
  6. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    +16
    Yeah...try 'menu', 'enter' and 'zero' :smashin:
    It's been a while since I had my 433HDE :rolleyes:
    What do you want to find out in there anyways ?
    Cheers, Lee
  7. Anuj
    Anuj
    I want to see the usage counter, I tried it with enter but it does not work, could it be something else?
  8. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    +16
    Do you have the newer aluminium remote or the older plastic one ?
    If it's the newer one perhaps they have changed the method - I had the older one.
    Sorry but I have no more ideas :thumbsdow
    Cheers, Lee
  9. Anuj
    Anuj
    yeah, it is the new one, does anybody else out there have any ideas?
