pioneer 433 power problem
Discussion in 'Plasma TVs' started by chmaiden, Aug 20, 2005.
  1. chmaiden
    chmaiden
    Nov 10, 2003
    112
    16
    guys...just switched on the pioneer and there was a big old bang, bit of a flash on the screen and the circuit tripped in the house. turned it all off and left it for a bit, but...
    got power to the media box, but the screen is blank with the standby light flashing....
    any ideas? big/expensive repair or ?
    tia
    c
  2. ikon66
    ikon66
    Mar 22, 2005
    397
    Tyne & Wear
    +7
    power supply I would guess :confused:
  3. Skeets_de
    Skeets_de
    Classic symptoms of the High Voltage Power Supply blowing. :(
  4. chmaiden
    chmaiden
    Nov 10, 2003
    112
    16
    how much is that going to cost to get repaired roughly?! the set is about 2 years old...any redress from pioneer?
  5. Skeets_de
    Skeets_de
    EU Warranty is 2 years in Germany and since the UK is in the EU...sometimes.
    As to repair costs it depends on whether it was just a capacitor or diode or the whole P/S or if it took something else with it. The bang indicates a filter capacitor short circuiting which drew heavy current resulting in the breaker popping. :rolleyes:
